Hi,
Is possible to delay the accept from analog input ?
For example:
When the input value go down the minimun for x second then relay = ON
thank’s
Hi,
For example:
thank’s
Hi,
No this fonction is not implanted.
Best regards,
Patrick
But if we pay for this modify ??? or I can have the source to make this implementation???
We never give the source code…
We can write the fonction for you but you must send your request at support@gce-electronics.com
and explain exactly what you want.
We shall send you in return the developpement cost.
Best regards,
Patrick
