🌡 Collection de Widgets analogiques (CANVAS-GAUGES)
Voici un l’exemple de mon Dashboard avec widgets revisitĂ©s, suivant les tutos de @fgtoul
, pilotage avec ecodevice et entree analogique
javascript correspondant pour les 4 linéaires
<canvas style="margin-top:15px;" id=daniel10 data-type="linear-gauge"
        data-width="290"
        data-height="100"
        data-min-value="0"
        data-max-value="15"
        data-border-radius="0"
        data-borders="0"
        data-bar-begin-circle="false"
        data-title="Intensité PH 1"
        data-units="Amperes"
        data-tick-side="left"
        data-bar-stroke-width="3"
        data-color-bar-stroke="transparent"
        data-highlights='[
          { "from": 0, "to": 5, "color": "green" },
          { "from":5, "to": 10, "color": "rgba(255,255,0,1)" },
          { "from": 10, "to": 15, "color": "rgba(255,30,0,1)" }
        data-major-ticks="0,5,10,15"
        data-color-minor-ticks="blue"
        data-minor-ticks="5"
        data-color-plate="transparent"
        data-color-numbers="#ccc"
        data-color-major-ticks="green"
        data-color-bar-stroke="#444"
        data-number-side="left"
        data-needle-side="right"
        data-animate-on-init=""
        data-animated-value="true"
        data-stroke-ticks="true"
        data-color-title="#fff"
        data-color-units="#fff"
        data-color-numbers="#eee"
        data-color-needle-start="rgba(240, 128, 128, 1)"
        data-color-needle-end=""
        data-value-box="true"
       data-color-value-text="#fff"
       data-color-value-box-background="red"
        data-animation-rule="bounce"
        data-animation-duration="500"
        data-font-value="Led"
        data-font-numbers-size="40"
        data-font-title-size="40"
        data-font-units-size="80"
        data-font-numbers="Led"
        data-font-units="mistral"
        data-color-bar-progress = "rgba(245,125,125,1)" //bar de progression debut
        data-color-needle="yellow" //aiguille
     // data-color-bar-end="transparent"
      data-color-bar-progress-end="red"     //bar de progression  fin
      data-bar-progress="true"
></canvas>;
      <script async src="//cdn.rawgit.com/Mikhus/canvas-gauges/gh-pages/download/2.1.5/all/gauge.min.js""/>
et celui pour widget les circulaires
<center>
    <canvas id=daniel14 style="margin-top:15px;"  data-type="radial-gauge"
        data-width="240"
        data-height="240"
        data-units="°C"
        data-title="false"
      data-value="true"
        data-min-value="0"
        data-max-value="40"
        data-major-ticks="0,10,20,30,40""
        data-minor-ticks="2"
        data-stroke-ticks="false"
        data-highlights='[
            { "from": 0, "to": 10, "color": "rgba(0,255,0,.15)" },
            { "from":10, "to": 20, "color": "rgba(255,30,0,.25)" },
            { "from": 20, "to": 30, "color": "rgba(255,255,0,1)   " },
            { "from": 30, "to": 40, "color": "rgba(255,0,225,.25)" }
        data-color-plate="#222"
        data-color-major-ticks="#f5f5f5"
        data-color-minor-ticks="#ddd"
        data-color-units="#ccc"
        data-color-needle-end="rgba(255, 160, 122, .9)"
        data-animation="false"
        data-value-int="2"
        data-value-dec="1"
        data-font-numbers-size="30"
        data-font-units-size="30"
        data-font-value-size="35"
></canvas>
</center>
Script source de données
a=datasources["linky"]["response"]["T1_IINST1"];
b=datasources["linky"]["response"]["T1_IINST2"];
c=datasources["linky"]["response"]["T1_IINST3"];
d=((datasources["STATUS"]["response"]["analog0"] * 0.000050354) - 0.25) / 0.028;
e=((datasources["STATUS"]["response"]["analog1"] * 0.000050354) - 0.25) / 0.028;
f=datasources["linky"]["response"]["T1_PAPP"] /1000;
var gauge1 = document.gauges.get('daniel10');
gauge1.value=a;
var gauge2 = document.gauges.get('daniel11');
gauge2.value=b;
var gauge3 = document.gauges.get('daniel12');
gauge3.value=c;
var gauge4 = document.gauges.get('daniel13');
gauge4.value=d;
var gauge5 = document.gauges.get('daniel14');
gauge5.value=e;
var gauge6 = document.gauges.get('daniel15');
gauge6.value=f;
return `
<div>Javascript pour mise Ă  jour des jauges</div>
Cordialement, Daniel
Pas maldu tout les compteurs personalisé
Bonsoir
Un peux hors sujet ; j’ai installer une girouette et j’essaie de mettre votre rosace ; que j’utilisai sur la V4 @fgtoul mais rien de s’affiche en V5.
C’est sur je fais une erreur mais laquelle ? :thinking:
bonsoir @tous30
je pense qu’il manque la rĂ©fĂ©rence au script externe.
voir l’article plus complet :
Jauges analogiques — GCE Electronics (gce-electronics.com)
Merci je regarde cela
Oups : je n’avais pas vu qu’il s’agissait de l’IPX800 V5 :blush:
Outre l’utilisation de l’API V5, le widget ne fonctionne pas tel quel sur V5 et demande une adaptation : le javascript doit ĂȘtre insĂ©rĂ© dans des balises.
Exemple avec le Widget pH :
<canvas style="margin-top:15px;" id=fgtoul7 data-type="linear-gauge"
        data-width="220"
        data-height="75"
        data-min-value="4"
        data-max-value="9"
        data-borders="0"
        data-title=""
        data-units=""
        data-value="5.2"
        data-highlights='[{"from": 7.2, "to": 7.8, "color": "green"}]'
        data-major-ticks="4,5,6,7,8,9"
        data-minor-ticks="1"
        data-color-major-ticks="#ccc"
        data-needle-side="left"
></canvas>
 let IPX_apiKey="xxxxx"; //renseignez votre apikey IPX
 let idX200="5046272"; //X200 sur canal 0 de X-Bridge
 var gauge7;
 function initb() {
       getStateb((ipxb) => {
       gauge7 = document.gauges.get("fgtoul7");
       gauge7.value=parseFloat(ipxb.anaPhVal)/100; // pH sur X200 canal 0 sur X-Bridge
function getStateb(cb) {
        fetch("/api/ebx/x200/" + idX200 + "?ApiKey=" + IPX_apiKey, {method: "GET"}).then((ret) => { // Get IPX object
          ret.json().then((ipxb) => {
            cb(ipxb);
      /* Auto refresh (optional) */
function autoRefreshb() {
        setInterval(() => {
          initb();
        }, 60000); // 60 sec
initb();
autoRefreshb();
</script>
Rien de grave
Pour le moment ça ne fonctionne pas mais il faut que je regarde et modifie cela :: ```
fetch(« /api/ebx/x200/ Â»
Encore merci
Dans l’exemple, le GET par Api est adaptĂ© au pH sur X200.
Il faut effectivement rĂ©cupĂ©rer la valeur analogique de votre Girouette par la requĂȘte adaptĂ©e
Bonjour @fgtoul
Je n’arrive pas à faire fonctionner ce widget HTML
J’ai modifier le chemin soit ( rĂ©cupĂ©rĂ© via API DECK)
        fetch("/api/object/function/1048576"?ApiKey=" + IPX_apiKey, {method: "GET"}).then((ret) => {
J’ai aussi modifiĂ©
en mettant gauge7.value=150 ou ("150") pour faire des essais mais sans succĂšs .
L’ APIkey Ă  bien Ă©tĂ© renseignĂ© .
Merci de votre aide.
Bien voila ça fonctionne.
Je vous joint le code complet adapté pour une utilisation sur la V5
<center>
    <canvas id=fgtoul7 style="margin-top:15px;" data-border-shadow-width="0"
    data-width : "200"
    data-height : "200"
    data-animation-duration="1500"
    data-animation-rule="linear"
    data-highlights="false"
    data-units="ᔍ"
    data-major-ticks="N,NE,E,SE,S,SW,W,NW,N"
    data-max-value="360"
    data-min-value="0"
    data-minor-ticks="22"
    data-borders="true"
    data-title="DIRECTION"
    data-color-needle-shadow-down="#222"
    data-color-border-outer-end="#ccc"
    data-color-border-outer="#ccc"
    data-border-outer-width="10"
    data-border-middle-width="0"
    data-border-inner-width="0"
    data-needle-width="3"
    data-needle-end="99"
    data-needle-start="75"
    data-needle-type="line"
    data-needle-circle-outer="false"
    data-needle-circle-size="15"
    data-color-needle-circle-outer="#ccc"
    data-color-circle-inner="#fff"
    data-value-text-shadow="false"
    data-value-box="false"
    data-color-needle="rgba(240, 128, 128, 1)"
    data-color-plate="#33a"
    data-start-angle="180"
    data-ticks-angle="360"
    data-animation-target="plate"
    data-color-title="#f5f5f5"
    data-font-title-size="19"
></canvas>
    </center>
<script async src="//cdn.rawgit.com/Mikhus/canvas-gauges/gh-pages/download/2.1.5/all/gauge.min.js" > </script>
 let IPX_apiKey="votre APIKEY  systeme APIKEY"; //renseignez votre apikey IPX
 var gauge7;
 function initb() {
       gauge7.value=(ipxb.anaRealValue) ;
        fetch( "/api/object/function/1048576?ApiKey=" + IPX_apiKey, {method: "GET"}).then((ret) => {
            cb(ipxb);
        setInterval(() => {
          initb();
        }, 6000); // 6 sec
initb();
autoRefreshb();
</script>
bonjour @tous30
beau travail d’adaptation :+1:
pour les lecteurs : pensez Ă  renseigner votre apiKey dans le code, ainsi qu’à modifier l’url de la requĂȘte en fonction de votre configuration.
Ici, @tous30 a liĂ© la valeur analogique du capteur « girouette Â» Ă  l’entrĂ©e d’un objet Fonction ayant 1048576 pour ID, puis utilise le rĂ©sultat pour affichage dans le widget. .
Le mérite vous revient @fgtoul
Est-ce que votre ip800v5 reboot a chaque fois que vos widgets se rafraichissent ?
Sur le mien quand je calcul ma conso electrique (soustraction de 2 valeurs), il reboote.
JC
les appels API dans les widgets HTML posent problĂšme sur V5.
Une analyse du problĂšme est en cours.
Normalement, l’ipx ne reboote pas, mais perd la connexion rĂ©seau.
bonne journée.
Bonjour Ă  tous, super travail fgtoul !!! Je fait appel Ă  vous car j’ai suivi le wiki mais j’ai dĂč passer Ă  cĂŽtĂ© de quelques choses. cela fait 2 jours et je trouve pas.
J’ai mis en place les diffĂ©rent Ă©lĂ©ments dans mon ipx800v4 Code, script, data sources
tout s’affiche correctement mais je n’ai pas la valeur de ma tempĂ©rature ext. Quelle est la manip pour que ma jauge affiche l’entrĂ©e analogique dĂ©sirĂ©?
Merci pour votre aide
Bonjour Domo31
les jauges sont mises Ă  jour par le javascript :slight_smile:
Dans le fichier status : xxx.xxx.xxx.xxx:yyyy/user/status.xml vous avez la liste des entrées sorties EX:
<analogV31>0</analogV31>
<xths01>0</xths01>
<xths02>0</xths02>
<xths03>0</xths03>
<xths11>0</xths11>
Puis dans le code JAVAscript aprĂšs response [vous mettez la variable que vous souhaitez (Ex : xths1 ). Pensez que les valeur sont brut donc il faut les convertir (Ex 175.72 / 65535 )- 46.85 )
EX
a=((datasources["STATUS"]["response"]["xths1"] *175.72/65535 )-46.85).toFixed(2);
Bonsoir fgtoul, dĂ©solĂ© je ne suis vraiment pas dans la programmation pousser. Pourriez vous me guider, j’ai une sonde x-thl , ma config est comme ci dessous, c’est Ă  la place des pointiller que je dois rentrĂ© la bonne donnĂ©e? Mais laquelle car la sonde x-thl est sur le bus + et - et le 3.3v.
a=(((datasources[« STATUS Â»][« response Â»][« â€Š Â»] * 0.00323)- 1.63) / 0.0326).toFixed(2);
var gauge4 = document.gauges.get(â€č tempAir â€ș);
gauge4.value=Math.floor(a);
return `
Merci pour votre aide Domo 31
oui, c’est bien là qu’il faut mettre le nom de la ressource XTHS01 ou XTHS04,
a=(((datasources["STATUS"]["response"]["xths01"] * 0.00323)- 1.63) / 0.0326).toFixed(2);
NB :
  • XTHS01,02,03 concernent le X-THL1 avec dans l’ordre temp, humiditĂ©, luminositĂ©,
  • XTHS04,05,06 concernent le X-THL2 avec dans l’ordre temp, humiditĂ©, luminositĂ©,
  • etc
  • La base de donnĂ©es créée sur le dashboard doit ĂȘtre nommĂ©e comme dans le code, c’est Ă  dire STATUS.
