Communicate directly via the com port in labview
Hello, Did you try to communicate directly via the com port in labview? The FTDI supports two modes of the mode of communication by virtual com port or direct mode via USB. In the second case you need to install the drivers D2XX.
Please post your question in an other post and not at the and of one existant.
Don’t forget to use au good subjet.
Use the search motor with « labview ». There already are some responses.
Thanks
Thomas
PS : Post split.
