Mini-tuto NRX800 : Tableau de bord
Un petit flow en partage qui affiche des infos du NRX800 et permet de controler les IO, lancer un backup des flows, et effectuer un reboot ou un arrêt du NRX800
Il faut importer le flow
Coller le flow json et importer
Et déployer
Le dashboard est accessible http://IP du NRX800:1880/ui
Il faut installer via la palette le node « @terranlabs/email-nodes »
Code du flow
[{"id":"9cf3a6d.1104258","type":"tab","label":"NRX800","disabled":false,"info":""},{"id":"538510015ef875bb","type":"group","z":"9cf3a6d.1104258","name":"Système","style":{"fill":"#e3f3d3","label":true,"color":"#001f60"},"nodes":["d4feb199.b898b","c0682e5c.a4fc","95ae4c48.9f606","4bae8072.e81c2","92285ea6.f97a7","404f06.1e77b0fc","b2e972ab7f704f9d","345c5fb5d2d3dde7","87c070af5ea7bc19","c95eeba434e27c53","2be04c82.d0af74","5e6e69bb.0e1d38","ad4498e0.e7c278","a8dc2f34.5e32b","a508a5b7.89a128"],"x":54,"y":39,"w":992,"h":289.5},{"id":"9155cb6dade1b14a","type":"group","z":"9cf3a6d.1104258","name":"Shell","style":{"fill":"#e3f3d3","label":true,"color":"#001f60"},"nodes":["f4592b30.2f0528","4b4a0861.092b28","6c63dd0ccd89e489","8691b172816d200d","f7da32e9909166a9","8c59eea02ffacbaa","413c01ffb39242e1","4093b7caf12944c2"],"x":54,"y":531.5,"w":832,"h":157},{"id":"40e33d0d38114572","type":"group","z":"9cf3a6d.1104258","name":"OS","style":{"fill":"#e3f3d3","label":true,"color":"#001f60"},"nodes":["19fadb42.3d0c25","9cce8e0f.766f7","31113ee5af599411","2f2d6236c424abc9","b1f64e1b1601f2ea","53046e807ae74d43","2834bbfe0126397b","11cceabbb6365f6b"],"x":54,"y":351.5,"w":992,"h":157},{"id":"edbabdee2e378844","type":"group","z":"9cf3a6d.1104258","name":"Backup flows Node-red + IP du NRX800","style":{"fill":"#e3f3d3","label":true,"color":"#000000"},"nodes":["d891b81710a2a3f5","101bd152921ffcf3","7fdb606658b5f6be","e9d49bfbe488d474","cccc4c91b72d8134","70cb342abb017d11","698a29e215b57edb","a03e8d2dc156d39b"],"x":54,"y":719,"w":992,"h":149.5,"info":"## "},{"id":"a94030bac4b45dd3","type":"group","z":"9cf3a6d.1104258","name":"","style":{"fill":"#e3f3d3","label":true,"color":"#001f60"},"nodes":["1d018eafd8bf1522","6a5f18a5026c49df","341eb8890ae2f075","73d446ebd39f3adf","8e37025cfbbdd215","4da4b4d2cd323168","911254c9361dcc85","6278b8c855a234ec","5f250cb357f3a7ca"],"x":1068,"y":33,"w":904,"h":894},{"id":"1d018eafd8bf1522","type":"group","z":"9cf3a6d.1104258","g":"a94030bac4b45dd3","name":"INPUT 1 to Relay 1","style":{"label":true,"color":"#001f60"},"nodes":["1e0d57267a689967","425964c119581534","2a6c1901f8f0f23d","e8adc2041f58d458","8f1fb49bcf1865c3","a782add2800bddd7"],"x":1094,"y":59,"w":412,"h":162},{"id":"6a5f18a5026c49df","type":"group","z":"9cf3a6d.1104258","g":"a94030bac4b45dd3","name":"INPUT 1 to Relay 2","style":{"label":true,"color":"#001f60"},"nodes":["0e08f995b9e53600","c32a21f2f1238ae8","869c3cdf10dec313","1df3923788314f2d","e7f11e9cf742d51a","94ba44f4d8d2ee33"],"x":1534,"y":59,"w":412,"h":162},{"id":"341eb8890ae2f075","type":"group","z":"9cf3a6d.1104258","g":"a94030bac4b45dd3","name":"INPUT 1 to Relay 3","style":{"label":true,"color":"#001f60"},"nodes":["afc35bf01a1b5ccc","3937c11b3040a52a","69b57d017e0bcca1","c30e694cece03844","6dc0bf7d36c2ec05","311b550de599234b"],"x":1094,"y":239,"w":412,"h":162},{"id":"73d446ebd39f3adf","type":"group","z":"9cf3a6d.1104258","g":"a94030bac4b45dd3","name":"INPUT 1 to Relay 4","style":{"label":true,"color":"#001f60"},"nodes":["0f418d2ec7f17eb0","5c194144f8b62a75","8c3d4c6410f535db","8eaed897cf40b94c","35b29966db053985","8d464ffecac89b4a"],"x":1534,"y":239,"w":412,"h":162},{"id":"8e37025cfbbdd215","type":"group","z":"9cf3a6d.1104258","g":"a94030bac4b45dd3","name":"INPUT 1 to Relay 5","style":{"label":true,"color":"#001f60"},"nodes":["0531e8951ede7ae8","1f5bf931c2bd9242","e5fcac628fb52e29","cde3a838c2fe2c10","f9b1fec0578d4e03","942f4669a65de4cb"],"x":1094,"y":419,"w":412,"h":162},{"id":"4da4b4d2cd323168","type":"group","z":"9cf3a6d.1104258","g":"a94030bac4b45dd3","name":"INPUT 1 to Relay 6","style":{"label":true,"color":"#001f60"},"nodes":["5897a9b9775b68f8","9d59bb358821b9f9","7ae552edbcab9253","cf4469c22ba26ccd","b1b88bf0a4776502","a664b44fe7286d9f"],"x":1534,"y":419,"w":412,"h":162},{"id":"911254c9361dcc85","type":"group","z":"9cf3a6d.1104258","g":"a94030bac4b45dd3","name":"INPUT 1 to Relay 7","style":{"label":true,"color":"#001f60"},"nodes":["bd728d2f360248db","fa6caf70b80dec7c","ba5b70942dcc67b5","36dd6fa3a3a9bbef","1ad18492762c0a57","51ecfff83c3c42fe"],"x":1094,"y":599,"w":412,"h":162},{"id":"6278b8c855a234ec","type":"group","z":"9cf3a6d.1104258","g":"a94030bac4b45dd3","name":"INPUT 1 to Relay 8","style":{"label":true,"color":"#001f60"},"nodes":["6d79acf60528c5af","fa9e9ce5b429f483","6ec9bb8528a1a33c","dd77fe9f7545627d","70b0a5b3e527436b","bd9fcad032c28eec"],"x":1534,"y":599,"w":412,"h":162},{"id":"5f250cb357f3a7ca","type":"group","z":"9cf3a6d.1104258","g":"a94030bac4b45dd3","name":"User Led","style":{"label":true,"color":"#001f60"},"nodes":["59d206ab2e2f162f","51f980f9b97a7db7","0639371b74b6bd57","b68165cf6eb30256","7f4467274ef29c4f"],"x":1094,"y":779,"w":572,"h":122},{"id":"d4feb199.b898b","type":"ui_gauge","z":"9cf3a6d.1104258","g":"538510015ef875bb","name":"","group":"9cb4bc4d.96552","order":2,"width":3,"height":3,"gtype":"gage","title":"CPU Temperature","label":"C","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"35","seg2":"60","diff":false,"className":"","x":930,"y":120,"wires":[]},{"id":"c0682e5c.a4fc","type":"exec","z":"9cf3a6d.1104258","g":"538510015ef875bb","command":"vcgencmd measure_temp","addpay":false,"append":"","useSpawn":"","timer":"","name":"RPi Temp.","x":580,"y":100,"wires":[["95ae4c48.9f606"],[],[]]},{"id":"95ae4c48.9f606","type":"function","z":"9cf3a6d.1104258","g":"538510015ef875bb","name":"","func":"var str = msg.payload\nmsg.payload = str.substring(5,9);\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":740,"y":100,"wires":[["d4feb199.b898b","4bae8072.e81c2"]]},{"id":"f4592b30.2f0528","type":"ui_button","z":"9cf3a6d.1104258","g":"9155cb6dade1b14a","name":"","group":"75ffb55f4d9cf5a5","order":3,"width":0,"height":0,"passthru":false,"label":"Reboot","tooltip":"Rebooter le NRX800","color":"","bgcolor":"","className":"","icon":"","payload":"Voulez-vous vraiment rebooter le NRX800 ?","payloadType":"str","topic":"","topicType":"str","x":130,"y":580,"wires":[["6c63dd0ccd89e489"]]},{"id":"4b4a0861.092b28","type":"ui_button","z":"9cf3a6d.1104258","g":"9155cb6dade1b14a","name":"","group":"75ffb55f4d9cf5a5","order":4,"width":0,"height":0,"passthru":false,"label":"Shutdown","tooltip":"","color":"","bgcolor":"red","className":"","icon":"","payload":"","payloadType":"str","topic":"","topicType":"str","x":140,"y":640,"wires":[["8691b172816d200d"]]},{"id":"4bae8072.e81c2","type":"ui_chart","z":"9cf3a6d.1104258","g":"538510015ef875bb","name":"","group":"9cb4bc4d.96552","order":5,"width":6,"height":6,"label":"CPU Temperature","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"24","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"className":"","x":930,"y":80,"wires":[[]]},{"id":"92285ea6.f97a7","type":"exec","z":"9cf3a6d.1104258","g":"538510015ef875bb","command":"top -d 0.5 -b -n2 | grep \"Cpu(s)\"|tail -n 1 | awk '{print $2 + $4}'","addpay":false,"append":"","useSpawn":"","timer":"","winHide":false,"name":"CPU Load","x":580,"y":160,"wires":[["404f06.1e77b0fc"],[],[]]},{"id":"404f06.1e77b0fc","type":"ui_gauge","z":"9cf3a6d.1104258","g":"538510015ef875bb","name":"","group":"9cb4bc4d.96552","order":1,"width":3,"height":3,"gtype":"gage","title":"CPU","label":"CPU","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","diff":false,"className":"","x":970,"y":160,"wires":[]},{"id":"a508a5b7.89a128","type":"exec","z":"9cf3a6d.1104258","g":"538510015ef875bb","command":"df -h","addpay":false,"append":"","useSpawn":"","timer":"","winHide":false,"name":"Disk Usage","x":590,"y":280,"wires":[["a8dc2f34.5e32b"],[],[]]},{"id":"ad4498e0.e7c278","type":"ui_gauge","z":"9cf3a6d.1104258","g":"538510015ef875bb","name":"","group":"9cb4bc4d.96552","order":4,"width":3,"height":3,"gtype":"gage","title":"Disk","label":"%","format":"{{value}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","diff":false,"className":"","x":970,"y":280,"wires":[]},{"id":"a8dc2f34.5e32b","type":"function","z":"9cf3a6d.1104258","g":"538510015ef875bb","name":"","func":"var re = /([0-9]{2})%/\nvar idx = msg.payload.search(re);\nvar str = msg.payload;\nif (idx >=0) {\n    str = msg.payload.substring(idx, idx + 2);\n}\nmsg.payload = str;\nreturn msg;","outputs":1,"noerr":0,"x":760,"y":280,"wires":[["ad4498e0.e7c278"]]},{"id":"5e6e69bb.0e1d38","type":"inject","z":"9cf3a6d.1104258","g":"538510015ef875bb","name":"","props":[{"p":"payload"}],"repeat":"60","crontab":"","once":true,"onceDelay":"","topic":"","payload":"","payloadType":"date","x":170,"y":280,"wires":[["a508a5b7.89a128"]]},{"id":"19fadb42.3d0c25","type":"inject","z":"9cf3a6d.1104258","g":"40e33d0d38114572","name":"","props":[{"p":"payload"}],"repeat":"60","crontab":"","once":true,"onceDelay":"","topic":"","payload":"","payloadType":"date","x":170,"y":400,"wires":[["9cce8e0f.766f7"]]},{"id":"9cce8e0f.766f7","type":"exec","z":"9cf3a6d.1104258","g":"40e33d0d38114572","command":"hostname","addpay":false,"append":"-I","useSpawn":"","timer":"","winHide":false,"name":"Affiche Adresse IP","x":470,"y":400,"wires":[["31113ee5af599411"],[],[]]},{"id":"b2e972ab7f704f9d","type":"exec","z":"9cf3a6d.1104258","g":"538510015ef875bb","command":"free | grep Mem | awk '{print 100*($3/$2)}'","addpay":false,"append":"","useSpawn":"","timer":"","winHide":false,"name":"Used Memory","x":590,"y":220,"wires":[["345c5fb5d2d3dde7"],[],[]]},{"id":"345c5fb5d2d3dde7","type":"ui_gauge","z":"9cf3a6d.1104258","g":"538510015ef875bb","name":"","group":"9cb4bc4d.96552","order":3,"width":3,"height":3,"gtype":"gage","title":"Memoire","label":"%","format":"{{parseInt(value)}}","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","diff":false,"className":"","x":960,"y":220,"wires":[]},{"id":"31113ee5af599411","type":"function","z":"9cf3a6d.1104258","g":"40e33d0d38114572","name":"Extrait adresse ipv4","func":"// Regular expression to match an IPv4 address\nvar ipv4Regex = /\\b(?:\\d{1,3}\\.){3}\\d{1,3}\\b/;\n\n// Extract the IPv4 address using the regex\nvar ipv4Match = msg.payload.match(ipv4Regex);\n\n// If an IPv4 address is found, set it as the new payload\nif (ipv4Match) {\n    msg.payload = ipv4Match[0];\n} else {\n    msg.payload = \"Pas d'adresse IPv4 trouvée\";\n}\n\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":400,"wires":[["2f2d6236c424abc9"]]},{"id":"2f2d6236c424abc9","type":"ui_text","z":"9cf3a6d.1104258","g":"40e33d0d38114572","group":"dd70abe0.14cb38","order":1,"width":6,"height":2,"name":"","label":"Adresse IP","format":"{{msg.payload}}","layout":"col-center","className":"","style":false,"font":"","fontSize":"","color":"#000000","x":950,"y":400,"wires":[]},{"id":"87c070af5ea7bc19","type":"ui_switch","z":"9cf3a6d.1104258","g":"538510015ef875bb","name":"","label":"Cpu Temp Mémoire","tooltip":"","group":"9cb4bc4d.96552","order":6,"width":0,"height":0,"passthru":false,"decouple":"false","topic":"control","topicType":"str","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":true,"className":"","x":190,"y":160,"wires":[["c95eeba434e27c53"]]},{"id":"c95eeba434e27c53","type":"switch","z":"9cf3a6d.1104258","g":"538510015ef875bb","name":"Vérifie état switch","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":390,"y":160,"wires":[["c0682e5c.a4fc","92285ea6.f97a7","b2e972ab7f704f9d"],[]]},{"id":"2be04c82.d0af74","type":"inject","z":"9cf3a6d.1104258","g":"538510015ef875bb","name":"","props":[{"p":"payload"}],"repeat":"3","crontab":"","once":true,"onceDelay":"","topic":"","payload":"","payloadType":"date","x":170,"y":100,"wires":[["87c070af5ea7bc19"]]},{"id":"6c63dd0ccd89e489","type":"ui_toast","z":"9cf3a6d.1104258","g":"9155cb6dade1b14a","position":"dialog","displayTime":"3","highlight":"","sendall":true,"outputs":1,"ok":"OK","cancel":"Cancel","raw":true,"className":"","topic":"","name":"Confirmer Reboot","x":330,"y":580,"wires":[["f7da32e9909166a9"]]},{"id":"8691b172816d200d","type":"ui_toast","z":"9cf3a6d.1104258","g":"9155cb6dade1b14a","position":"dialog","displayTime":"3","highlight":"","sendall":true,"outputs":1,"ok":"OK","cancel":"","raw":false,"className":"","topic":"","name":"Confirmer l'arrêt","x":320,"y":640,"wires":[["413c01ffb39242e1"]]},{"id":"f7da32e9909166a9","type":"switch","z":"9cf3a6d.1104258","g":"9155cb6dade1b14a","name":"Teste la réponse","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"OK","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":540,"y":580,"wires":[["8c59eea02ffacbaa"]]},{"id":"8c59eea02ffacbaa","type":"exec","z":"9cf3a6d.1104258","g":"9155cb6dade1b14a","command":"sudo reboot","addpay":false,"append":"","useSpawn":"false","timer":"","winHide":false,"oldrc":false,"name":"Execute Reboot","x":780,"y":580,"wires":[[],[],[]]},{"id":"413c01ffb39242e1","type":"switch","z":"9cf3a6d.1104258","g":"9155cb6dade1b14a","name":"Teste la réponse","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"OK","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":540,"y":640,"wires":[["4093b7caf12944c2"]]},{"id":"4093b7caf12944c2","type":"exec","z":"9cf3a6d.1104258","g":"9155cb6dade1b14a","command":"sudo halt","addpay":false,"append":"","useSpawn":"false","timer":"","winHide":false,"oldrc":false,"name":"Execute halt","x":770,"y":640,"wires":[[],[],[]]},{"id":"b1f64e1b1601f2ea","type":"inject","z":"9cf3a6d.1104258","g":"40e33d0d38114572","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":true,"onceDelay":"","topic":"","payload":"","payloadType":"date","x":170,"y":460,"wires":[["53046e807ae74d43"]]},{"id":"53046e807ae74d43","type":"exec","z":"9cf3a6d.1104258","g":"40e33d0d38114572","command":"sudo cat /etc/os-release","addpay":false,"append":"","useSpawn":"","timer":"","winHide":false,"name":"Affiche Version Linux","x":480,"y":460,"wires":[["11cceabbb6365f6b"],[],[]]},{"id":"2834bbfe0126397b","type":"ui_text","z":"9cf3a6d.1104258","g":"40e33d0d38114572","group":"dd70abe0.14cb38","order":2,"width":6,"height":2,"name":"","label":"Version Linux","format":"{{msg.payload}}","layout":"col-center","className":"","style":false,"font":"","fontSize":"","color":"#000000","x":950,"y":460,"wires":[]},{"id":"11cceabbb6365f6b","type":"function","z":"9cf3a6d.1104258","g":"40e33d0d38114572","name":"Extrait pretty_name","func":"// Le message contient le texte multi-ligne dans msg.payload\nvar text = msg.payload;\n\n// Utiliser une expression régulière pour trouver la ligne contenant PRETTY_NAME\nvar match = text.match(/^PRETTY_NAME=\"(.+)\"$/m);\n\nif (match) {\n    // Si une correspondance est trouvée, extraire la valeur\n    msg.payload = match[1];\n} else {\n    // Si aucune correspondance n'est trouvée, renvoyer un message d'erreur\n    msg.payload = \"PRETTY_NAME not found\";\n}\n\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":460,"wires":[["2834bbfe0126397b"]]},{"id":"d891b81710a2a3f5","type":"inject","z":"9cf3a6d.1104258","g":"edbabdee2e378844","name":"Backup Node-red","props":[],"repeat":"","crontab":"00 00 * * *","once":false,"onceDelay":0.1,"topic":"","x":190,"y":820,"wires":[["e9d49bfbe488d474"]]},{"id":"101bd152921ffcf3","type":"function","z":"9cf3a6d.1104258","g":"edbabdee2e378844","name":"Construction de l'email","func":"const date = new Date()\nconst ip = msg.payload\n\nmsg.topic = `Backup-Node-red - ${date} - ${ip}`\n\nmsg.payload = `<h1>Backup des flows Node-red NRX800</h1>`\nmsg.attachments = [\n        { \n            filename: `flows.json`,\n            path: \"/home/nrx800/.node-red/flows.json\"\n        },\n        { \n            filename: `flows_cred.json`,\n            path: \"/home/nrx800/.node-red/flows_cred.json\"\n        },\n        { \n            filename: `package.json`,\n            path: \"/home/nrx800/.node-red/package.json\"\n        },\n        { \n            filename: `package-lock.json`,\n            path: \"/home/nrx800/.node-red/package-lock.json\"\n        }\n        ]\n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":800,"y":820,"wires":[["7fdb606658b5f6be"]]},{"id":"7fdb606658b5f6be","type":"e-mail","z":"9cf3a6d.1104258","g":"edbabdee2e378844","server":"smtp.orange.fr","port":"465","authtype":"BASIC","saslformat":false,"token":"oauth2Response.access_token","secure":true,"tls":true,"name":"xxxxxx@orange.fr","dname":"email","x":970,"y":820,"wires":[]},{"id":"e9d49bfbe488d474","type":"exec","z":"9cf3a6d.1104258","g":"edbabdee2e378844","command":"hostname","addpay":false,"append":"-I","useSpawn":"","timer":"","winHide":false,"name":"Récupére IP","x":390,"y":820,"wires":[["cccc4c91b72d8134"],[],[]]},{"id":"cccc4c91b72d8134","type":"function","z":"9cf3a6d.1104258","g":"edbabdee2e378844","name":"Extrait adresse ipv4","func":"// Regular expression to match an IPv4 address\nvar ipv4Regex = /\\b(?:\\d{1,3}\\.){3}\\d{1,3}\\b/;\n\n// Extract the IPv4 address using the regex\nvar ipv4Match = msg.payload.match(ipv4Regex);\n\n// If an IPv4 address is found, set it as the new payload\nif (ipv4Match) {\n    msg.payload = ipv4Match[0];\n} else {\n    msg.payload = \"No IPv4 address found\";\n}\n\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":590,"y":820,"wires":[["101bd152921ffcf3"]]},{"id":"70cb342abb017d11","type":"ui_button","z":"9cf3a6d.1104258","g":"edbabdee2e378844","name":"","group":"75ffb55f4d9cf5a5","order":1,"width":0,"height":0,"passthru":false,"label":"Backup flows","tooltip":"Envoyer par email le flows.json du NRX800","color":"","bgcolor":"","className":"","icon":"","payload":"Voulez-vous vraiment envoyer par email les flows.json du NRX800 ?","payloadType":"str","topic":"","topicType":"str","x":180,"y":760,"wires":[["698a29e215b57edb"]]},{"id":"698a29e215b57edb","type":"ui_toast","z":"9cf3a6d.1104258","g":"edbabdee2e378844","position":"dialog","displayTime":"3","highlight":"","sendall":true,"outputs":1,"ok":"OK","cancel":"Cancel","raw":true,"className":"","topic":"","name":"Confirmer Backup","x":410,"y":760,"wires":[["a03e8d2dc156d39b"]]},{"id":"a03e8d2dc156d39b","type":"switch","z":"9cf3a6d.1104258","g":"edbabdee2e378844","name":"Vérifie la réponse","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"OK","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":630,"y":760,"wires":[["e9d49bfbe488d474"]]},{"id":"1e0d57267a689967","type":"rpi-gpio out","z":"9cf3a6d.1104258","g":"1d018eafd8bf1522","name":"RLY 1","pin":"4","set":true,"level":"0","freq":"","out":"out","bcm":true,"x":1430,"y":140,"wires":[]},{"id":"425964c119581534","type":"rpi-gpio in","z":"9cf3a6d.1104258","g":"1d018eafd8bf1522","name":"INPUT 1","pin":"20","intype":"tri","debounce":"25","read":true,"bcm":true,"x":1170,"y":180,"wires":[["2a6c1901f8f0f23d"]]},{"id":"2a6c1901f8f0f23d","type":"function","z":"9cf3a6d.1104258","g":"1d018eafd8bf1522","name":"Not","func":"// GCE\n// simple  inverter function\n\nif(msg.payload == 1)\n{\n    msg.payload = 0;  \n}\nelse{\n    msg.payload = 1;\n}\nnode.warn(\"relay 1 = \" + msg.payload);\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1310,"y":180,"wires":[["1e0d57267a689967"]]},{"id":"e8adc2041f58d458","type":"ui_switch","z":"9cf3a6d.1104258","g":"1d018eafd8bf1522","name":"","label":"Relais 1","tooltip":"","group":"80594882fcd06ad2","order":1,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"1","onvalueType":"num","onicon":"","oncolor":"","offvalue":"0","offvalueType":"num","officon":"","offcolor":"","animate":false,"className":"","x":1180,"y":140,"wires":[["1e0d57267a689967"]]},{"id":"8f1fb49bcf1865c3","type":"inject","z":"9cf3a6d.1104258","g":"1d018eafd8bf1522","name":"0","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"0","payloadType":"num","x":1190,"y":100,"wires":[["1e0d57267a689967"]],"icon":"font-awesome/fa-toggle-off"},
Voila c’est un premier jet, j’ajouterais des fonctions au fur et à mesure au flow et partagerais bien sur ! :slight_smile:
@GCE Pas de souci pour intégrer dans l’image du NRX800 :wink:
Par contre j’ai du couper le flow en deux à cause du message suivant :
« Une erreur est survenue : Corps is limited to 32000 characters; you entered 65979. »
la 2de partie du flow
2d partie du code
{"id":"a782add2800bddd7","type":"inject","z":"9cf3a6d.1104258","g":"1d018eafd8bf1522","name":"1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"1","payloadType":"num","x":1410,"y":100,"wires":[["1e0d57267a689967"]],"icon":"node-red-dashboard/ui_switch.png"},{"id":"0e08f995b9e53600","type":"rpi-gpio out","z":"9cf3a6d.1104258","g":"6a5f18a5026c49df","name":"RLY 2","pin":"5","set":true,"level":"0","freq":"","out":"out","bcm":true,"x":1870,"y":140,"wires":[]},{"id":"c32a21f2f1238ae8","type":"inject","z":"9cf3a6d.1104258","g":"6a5f18a5026c49df","name":"0","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"0","payloadType":"num","x":1630,"y":100,"wires":[["0e08f995b9e53600"]],"icon":"font-awesome/fa-toggle-off"},{"id":"869c3cdf10dec313","type":"inject","z":"9cf3a6d.1104258","g":"6a5f18a5026c49df","name":"1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"1","payloadType":"num","x":1850,"y":100,"wires":[["0e08f995b9e53600"]],"icon":"node-red-dashboard/ui_switch.png"},{"id":"1df3923788314f2d","type":"rpi-gpio in","z":"9cf3a6d.1104258","g":"6a5f18a5026c49df","name":"INPUT 2","pin":"21","intype":"tri","debounce":"25","read":true,"bcm":true,"x":1610,"y":180,"wires":[["e7f11e9cf742d51a"]]},{"id":"e7f11e9cf742d51a","type":"function","z":"9cf3a6d.1104258","g":"6a5f18a5026c49df","name":"Not","func":"// GCE\n// simple  inverter function\n\nif(msg.payload == 1)\n{\n    msg.payload = 0;  \n}\nelse{\n    msg.payload = 1;\n}\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1730,"y":180,"wires":[["0e08f995b9e53600"]]},{"id":"94ba44f4d8d2ee33","type":"ui_switch","z":"9cf3a6d.1104258","g":"6a5f18a5026c49df","name":"","label":"Relais 2","tooltip":"","group":"80594882fcd06ad2","order":2,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"1","onvalueType":"num","onicon":"","oncolor":"","offvalue":"0","offvalueType":"num","officon":"","offcolor":"","animate":false,"className":"","x":1620,"y":140,"wires":[["0e08f995b9e53600"]]},{"id":"afc35bf01a1b5ccc","type":"rpi-gpio out","z":"9cf3a6d.1104258","g":"341eb8890ae2f075","name":"RLY 3","pin":"6","set":true,"level":"0","freq":"","out":"out","bcm":true,"x":1430,"y":320,"wires":[]},{"id":"3937c11b3040a52a","type":"rpi-gpio in","z":"9cf3a6d.1104258","g":"341eb8890ae2f075","name":"INPUT 3","pin":"22","intype":"tri","debounce":"25","read":true,"bcm":true,"x":1170,"y":360,"wires":[["69b57d017e0bcca1"]]},{"id":"69b57d017e0bcca1","type":"function","z":"9cf3a6d.1104258","g":"341eb8890ae2f075","name":"Not","func":"// GCE\n// simple  inverter function\n\nif(msg.payload == 1)\n{\n    msg.payload = 0;  \n}\nelse{\n    msg.payload = 1;\n}\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1290,"y":360,"wires":[["afc35bf01a1b5ccc"]]},{"id":"c30e694cece03844","type":"ui_switch","z":"9cf3a6d.1104258","g":"341eb8890ae2f075","name":"","label":"Relais 3","tooltip":"","group":"80594882fcd06ad2","order":3,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"1","onvalueType":"num","onicon":"","oncolor":"","offvalue":"0","offvalueType":"num","officon":"","offcolor":"","animate":false,"className":"","x":1180,"y":320,"wires":[["afc35bf01a1b5ccc"]]},{"id":"6dc0bf7d36c2ec05","type":"inject","z":"9cf3a6d.1104258","g":"341eb8890ae2f075","name":"0","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"0","payloadType":"num","x":1190,"y":280,"wires":[["afc35bf01a1b5ccc"]],"icon":"font-awesome/fa-toggle-off"},{"id":"311b550de599234b","type":"inject","z":"9cf3a6d.1104258","g":"341eb8890ae2f075","name":"1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"1","payloadType":"num","x":1410,"y":280,"wires":[["afc35bf01a1b5ccc"]],"icon":"node-red-dashboard/ui_switch.png"},{"id":"0f418d2ec7f17eb0","type":"rpi-gpio out","z":"9cf3a6d.1104258","g":"73d446ebd39f3adf","name":"RLY 4","pin":"12","set":true,"level":"0","freq":"","out":"out","bcm":true,"x":1870,"y":320,"wires":[]},{"id":"5c194144f8b62a75","type":"rpi-gpio in","z":"9cf3a6d.1104258","g":"73d446ebd39f3adf","name":"INPUT 4","pin":"23","intype":"tri","debounce":"25","read":true,"bcm":true,"x":1610,"y":360,"wires":[["8c3d4c6410f535db"]]},{"id":"8c3d4c6410f535db","type":"function","z":"9cf3a6d.1104258","g":"73d446ebd39f3adf","name":"Not","func":"// GCE\n// simple  inverter function\n\nif(msg.payload == 1)\n{\n    msg.payload = 0;  \n}\nelse{\n    msg.payload = 1;\n}\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1730,"y":360,"wires":[["0f418d2ec7f17eb0"]]},{"id":"8eaed897cf40b94c","type":"ui_switch","z":"9cf3a6d.1104258","g":"73d446ebd39f3adf","name":"","label":"Relais 4","tooltip":"","group":"80594882fcd06ad2","order":4,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"1","onvalueType":"num","onicon":"","oncolor":"","offvalue":"0","offvalueType":"num","officon":"","offcolor":"","animate":false,"className":"","x":1620,"y":320,"wires":[["0f418d2ec7f17eb0"]]},{"id":"35b29966db053985","type":"inject","z":"9cf3a6d.1104258","g":"73d446ebd39f3adf","name":"0","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"0","payloadType":"num","x":1630,"y":280,"wires":[["0f418d2ec7f17eb0"]],"icon":"font-awesome/fa-toggle-off"},{"id":"8d464ffecac89b4a","type":"inject","z":"9cf3a6d.1104258","g":"73d446ebd39f3adf","name":"1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"1","payloadType":"num","x":1850,"y":280,"wires":[["0f418d2ec7f17eb0"]],"icon":"node-red-dashboard/ui_switch.png"},{"id":"0531e8951ede7ae8","type":"rpi-gpio out","z":"9cf3a6d.1104258","g":"8e37025cfbbdd215","name":"RLY 5","pin":"13","set":true,"level":"0","freq":"","out":"out","bcm":true,"x":1430,"y":500,"wires":[]},{"id":"1f5bf931c2bd9242","type":"rpi-gpio in","z":"9cf3a6d.1104258","g":"8e37025cfbbdd215","name":"INPUT 5","pin":"24","intype":"tri","debounce":"25","read":true,"bcm":true,"x":1170,"y":540,"wires":[["e5fcac628fb52e29"]]},{"id":"e5fcac628fb52e29","type":"function","z":"9cf3a6d.1104258","g":"8e37025cfbbdd215","name":"Not","func":"// GCE\n// simple  inverter function\n\nif(msg.payload == 1)\n{\n    msg.payload = 0;  \n}\nelse{\n    msg.payload = 1;\n}\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1290,"y":540,"wires":[["0531e8951ede7ae8"]]},{"id":"cde3a838c2fe2c10","type":"ui_switch","z":"9cf3a6d.1104258","g":"8e37025cfbbdd215","name":"","label":"Relais 5","tooltip":"","group":"80594882fcd06ad2","order":5,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"1","onvalueType":"num","onicon":"","oncolor":"","offvalue":"0","offvalueType":"num","officon":"","offcolor":"","animate":false,"className":"","x":1180,"y":500,"wires":[["0531e8951ede7ae8"]]},{"id":"f9b1fec0578d4e03","type":"inject","z":"9cf3a6d.1104258","g":"8e37025cfbbdd215","name":"0","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"0","payloadType":"num","x":1190,"y":460,"wires":[["0531e8951ede7ae8"]],"icon":"font-awesome/fa-toggle-off"},{"id":"942f4669a65de4cb","type":"inject","z":"9cf3a6d.1104258","g":"8e37025cfbbdd215","name":"1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"1","payloadType":"num","x":1410,"y":460,"wires":[["0531e8951ede7ae8"]],"icon":"node-red-dashboard/ui_switch.png"},{"id":"5897a9b9775b68f8","type":"rpi-gpio out","z":"9cf3a6d.1104258","g":"4da4b4d2cd323168","name":"RLY 6","pin":"16","set":true,"level":"0","freq":"","out":"out","bcm":true,"x":1870,"y":500,"wires":[]},{"id":"9d59bb358821b9f9","type":"rpi-gpio in","z":"9cf3a6d.1104258","g":"4da4b4d2cd323168","name":"INPUT 6","pin":"25","intype":"tri","debounce":"25","read":true,"bcm":true,"x":1610,"y":540,"wires":[["7ae552edbcab9253"]]},{"id":"7ae552edbcab9253","type":"function","z":"9cf3a6d.1104258","g":"4da4b4d2cd323168","name":"Not","func":"// GCE\n// simple  inverter function\n\nif(msg.payload == 1)\n{\n    msg.payload = 0;  \n}\nelse{\n    msg.payload = 1;\n}\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1730,"y":540,"wires":[["5897a9b9775b68f8"]]},{"id":"cf4469c22ba26ccd","type":"ui_switch","z":"9cf3a6d.1104258","g":"4da4b4d2cd323168","name":"","label":"Relais 6","tooltip":"","group":"80594882fcd06ad2","order":6,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"1","onvalueType":"num","onicon":"","oncolor":"","offvalue":"0","offvalueType":"num","officon":"","offcolor":"","animate":false,"className":"","x":1620,"y":500,"wires":[["5897a9b9775b68f8"]]},{"id":"b1b88bf0a4776502","type":"inject","z":"9cf3a6d.1104258","g":"4da4b4d2cd323168","name":"0","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"0","payloadType":"num","x":1630,"y":460,"wires":[["5897a9b9775b68f8"]],"icon":"font-awesome/fa-toggle-off"},{"id":"a664b44fe7286d9f","type":"inject","z":"9cf3a6d.1104258","g":"4da4b4d2cd323168","name":"1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"1","payloadType":"num","x":1830,"y":460,"wires":[["5897a9b9775b68f8"]],"icon":"node-red-dashboard/ui_switch.png"},{"id":"bd728d2f360248db","type":"rpi-gpio out","z":"9cf3a6d.1104258","g":"911254c9361dcc85","name":"RLY 7","pin":"17","set":true,"level":"0","freq":"","out":"out","bcm":true,"x":1430,"y":680,"wires":[]},{"id":"fa6caf70b80dec7c","type":"rpi-gpio in","z":"9cf3a6d.1104258","g":"911254c9361dcc85","name":"INPUT 7","pin":"26","intype":"tri","debounce":"25","read":true,"bcm":true,"x":1170,"y":720,"wires":[["ba5b70942dcc67b5"]]},{"id":"ba5b70942dcc67b5","type":"function","z":"9cf3a6d.1104258","g":"911254c9361dcc85","name":"Not","func":"// GCE\n// simple  inverter function\n\nif(msg.payload == 1)\n{\n    msg.payload = 0;  \n}\nelse{\n    msg.payload = 1;\n}\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1290,"y":720,"wires":[["bd728d2f360248db"]]},{"id":"36dd6fa3a3a9bbef","type":"ui_switch","z":"9cf3a6d.1104258","g":"911254c9361dcc85","name":"","label":"Relais 7","tooltip":"","group":"80594882fcd06ad2","order":7,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"1","onvalueType":"num","onicon":"","oncolor":"","offvalue":"0","offvalueType":"num","officon":"","offcolor":"","animate":false,"className":"","x":1180,"y":680,"wires":[["bd728d2f360248db"]]},{"id":"1ad18492762c0a57","type":"inject","z":"9cf3a6d.1104258","g":"911254c9361dcc85","name":"0","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"0","payloadType":"num","x":1190,"y":640,"wires":[["bd728d2f360248db"]],"icon":"font-awesome/fa-toggle-off"},{"id":"51ecfff83c3c42fe","type":"inject","z":"9cf3a6d.1104258","g":"911254c9361dcc85","name":"1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"1","payloadType":"num","x":1410,"y":640,"wires":[["bd728d2f360248db"]],"icon":"node-red-dashboard/ui_switch.png"},{"id":"6d79acf60528c5af","type":"rpi-gpio out","z":"9cf3a6d.1104258","g":"6278b8c855a234ec","name":"RLY 8","pin":"18","set":true,"level":"0","freq":"","out":"out","bcm":true,"x":1870,"y":680,"wires":[]},{"id":"fa9e9ce5b429f483","type":"rpi-gpio in","z":"9cf3a6d.1104258","g":"6278b8c855a234ec","name":"INPUT 8","pin":"27","intype":"tri","debounce":"25","read":true,"bcm":true,"x":1610,"y":720,"wires":[["6ec9bb8528a1a33c"]]},{"id":"6ec9bb8528a1a33c","type":"function","z":"9cf3a6d.1104258","g":"6278b8c855a234ec","name":"Not","func":"// GCE\n// simple  inverter function\n\nif(msg.payload == 1)\n{\n    msg.payload = 0;  \n}\nelse{\n    msg.payload = 1;\n}\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1730,"y":720,"wires":[["6d79acf60528c5af"]]},{"id":"dd77fe9f7545627d","type":"ui_switch","z":"9cf3a6d.1104258","g":"6278b8c855a234ec","name":"","label":"Relais 8","tooltip":"","group":"80594882fcd06ad2","order":8,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"1","onvalueType":"num","onicon":"","oncolor":"","offvalue":"0","offvalueType":"num","officon":"","offcolor":"","animate":false,"className":"","x":1620,"y":680,"wires":[["6d79acf60528c5af"]]},{"id":"70b0a5b3e527436b","type":"inject","z":"9cf3a6d.1104258","g":"6278b8c855a234ec","name":"0","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"0","payloadType":"num","x":1630,"y":640,"wires":[["6d79acf60528c5af"]],"icon":"font-awesome/fa-toggle-off"},{"id":"bd9fcad032c28eec","type":"inject","z":"9cf3a6d.1104258","g":"6278b8c855a234ec","name":"1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"1","payloadType":"num","x":1830,"y":640,"wires":[["6d79acf60528c5af"]],"icon":"node-red-dashboard/ui_switch.png"},{"id":"59d206ab2e2f162f","type":"rpi-gpio out","z":"9cf3a6d.1104258","g":"5f250cb357f3a7ca","name":"User Led","pin":"19","set":true,"level":"1","freq":"","out":"out","bcm":true,"x":1580,"y":840,"wires":[]},{"id":"51f980f9b97a7db7","type":"function","z":"9cf3a6d.1104258","g":"5f250cb357f3a7ca","name":"Send State","func":"// GCE\n// simple  inverter function\n\nif(msg.payload == 'ON')\n{\n    msg.payload = 0;  \n}\nelse{\n    msg.payload = 1;\n}\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1370,"y":860,"wires":[["59d206ab2e2f162f"]]},{"id":"0639371b74b6bd57","type":"inject","z":"9cf3a6d.1104258","g":"5f250cb357f3a7ca","name":"OFF","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"OFF","payloadType":"str","x":1190,"y":860,"wires":[["51f980f9b97a7db7"]],"icon":"font-awesome/fa-toggle-off"},{"id":"b68165cf6eb30256","type":"inject","z":"9cf3a6d.1104258","g":"5f250cb357f3a7ca","name":"ON","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"","payload":"ON","payloadType":"str","x":1190,"y":820,"wires":[["51f980f9b97a7db7"]],"icon":"node-red-dashboard/ui_switch.png"},{"id":"7f4467274ef29c4f","type":"ui_switch","z":"9cf3a6d.1104258","g":"5f250cb357f3a7ca","name":"","label":"User Led","tooltip":"","group":"80594882fcd06ad2","order":9,"width":0,"height":0,"passthru":true,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"1","onvalueType":"num","onicon":"","oncolor":"","offvalue":"0","offvalueType":"num","officon":"","offcolor":"","animate":false,"className":"","x":1380,"y":820,"wires":[["59d206ab2e2f162f"]]},{"id":"261fb6f5d2299087","type":"ui_spacer","z":"9cf3a6d.1104258","name":"spacer","group":"75ffb55f4d9cf5a5","order":2,"width":6,"height":1},{"id":"9cb4bc4d.96552","type":"ui_group","name":"Système","tab":"ad4a1223.94ae8","order":3,"disp":true,"width":"6","collapse":false,"className":""},{"id":"75ffb55f4d9cf5a5","type":"ui_group","name":"Shell","tab":"ad4a1223.94ae8","order":2,"disp":true,"width":"6","collapse":false,"className":""},{"id":"dd70abe0.14cb38","type":"ui_group","name":"OS","tab":"ad4a1223.94ae8","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"80594882fcd06ad2","type":"ui_group","name":"Relais","tab":"ad4a1223.94ae8","order":4,"disp":true,"width":"6","collapse":false,"className":""},{"id":"ad4a1223.94ae8","type":"ui_tab","z":"9cf3a6d.1104258","name":"NRX800 (Panneau Contrôle)","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
Salut @cce66 ,
Mes premiers pas sur Node Red aujourd’hui !
Je viens d’implémenter ton dashboard, ca marche super bien merci !
Au passage, je n’ai pas d’autres flux que ceux d’origine + celui-ci et j’ai 95.5% de charge CPU ?!
Étonnant non ?
EDIT : redémarrer plusieurs fois idem, puis d’un coup est redescendu à 5% !!!???
Merci.
